thawkins72 Posted April 24, 2022 Report Share Posted April 24, 2022 I have a Tuff Spa which worked perfectly, then I drained it and moved it May 2021. I refilled and started, but pump went bad. Replaced the pump with Gecko XP2, and jets surged and would then stop entirely. Replaced topside control panel and a cracked fuse on the motherboard. Now it surges for a few seconds (anywhere from 5 to 30 seconds), then the jets come on full speed s as normal. But that only happens for 15 seconds, then it shuts off and that process starts over again after a 2 minute delay. No error messages on the control panel at all. Waiting to see if the water temp changes IMG_8564.MOV Quote Link to comment Share on other sites More sharing options...
ratchett Posted April 25, 2022 Report Share Posted April 25, 2022 I'm no expert - but that almost sounds like a priming mode where the jet pump is trying to push out an air-lock in the system. When you refilled, did you fill through the filter well? Did you bleed any air out of the plumbing internally? That's the first thing I'd try Quote Link to comment Share on other sites More sharing options...
thawkins72 Posted April 25, 2022 Author Report Share Posted April 25, 2022 I filled directly into the well, made sure all jets were open, even did a bleed at the pump. Still the same issues…thanks for the reply though, appreciate the help Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted April 26, 2022 Report Share Posted April 26, 2022 Are you sure you wired the pump correctly? Quote Link to comment Share on other sites More sharing options...
