SHOWEM Posted July 12, 2021 Report Share Posted July 12, 2021 I have a hotspring flair and I have been using chlorine granules since I’ve owned it for a year now. I developed a rash I emptied it cleaned it thoroughly and refilled it. The test strips shows almost perfect balance water is crystal clear I come to the conclusion my skin is sensitive to chlorine,it doesn’t effect anyone else using it. Would going with bromine help my problem thanks in advance. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted July 12, 2021 Report Share Posted July 12, 2021 It's not the chlorine. Use ahhsome spa purge according to directions, drain and refill. Follow the dichlor/bleach method in the chemistry section, and watch your cc and ph. Hopefully this helps. There are numerous threads on unexplained rashes if it does not. 1 Quote Link to comment Share on other sites More sharing options...
SHOWEM Posted July 13, 2021 Author Report Share Posted July 13, 2021 Thanks for the reply I just ordered it and hopefully that will solve the problem Quote Link to comment Share on other sites More sharing options...
cranbiz Posted July 13, 2021 Report Share Posted July 13, 2021 What comes out of the plumbing in your tub will shock you. 2 Quote Link to comment Share on other sites More sharing options...
