Conehead147 Posted June 30, 2021 Report Share Posted June 30, 2021 Hi All Thank you in advance for any help with this issue. I recently got a 2008 Hot Springs Vista with a dual speed Jet 2. On the 2nd press initially the high speed pump setting kicks in but gradually over 10 minutes its drops off and the pressure decreases. Then if you stop all the jets including jet one and try activating it again it, the low pump (on 1 press of jet 2) kicks in and on the 2nd press turns off but the high pump does not kick in. Has any body encountered this Thanks Again Quote Link to comment Share on other sites More sharing options...
castletonia Posted June 30, 2021 Report Share Posted June 30, 2021 If the jet pressure is decreasing I would take a look at your filters. Dirty filters will reduce available water flow going to your pump. For the pump not kicking in on high, does that always happen or is it random? Could be a bad pump, could be a relay sticking on the circuit board, could be the button on the control panel or the control head behind it not sending the signal to the pump. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted July 1, 2021 Report Share Posted July 1, 2021 18 hours ago, castletonia said: Could be a bad pump, could be a relay sticking on the circuit board, 👍 Quote Link to comment Share on other sites More sharing options...
