Laurence 0 Posted January 19 Report Share Posted January 19 Hi, I have a balboa hottub and is just looking for some advice. When I adjust the heat temp the pump 1 high speed turns on, is that normal as I thought it only uses the low speed pump for filtering and heating. When it kicks in I can press jet one then it switches to low speed and still heats up. When I came back out a few hours later to check the temp the pump 1 high speed has turned back on again and doesn't shut off automatically until it reaches the desired temp. I have attached photos of my topside controller and the motherboard I am using is a balboa gs501sz. Any advice on this would be much appreciated. Thanks. Quote Link to post Share on other sites
CanadianSpaTech 419 Posted January 19 Report Share Posted January 19 Have you recently made any changes to the spa...new pump? Place the temp down 5 degrees and wait 30 seconds or so for the pump to stop and heat light to go out. No filter cycle running. It will take about 30 seconds for the heater to cool and pump to shut off. Then turn the temp back up so heat light comes on and pump starts. Does it start in hi speed or low speed? 1 Quote Link to post Share on other sites
Laurence 0 Posted January 19 Author Report Share Posted January 19 I have replaced 2 two speed pump before yes but am sure I put it the same wiring as before and I also replaced the motherboard and topside controller as the motherboard block got fried. And the topside controller i had was not compatible with my new motherboard. So I replaced that also with the correct one. I turned down the temp but the low speed is still running and heat light is now off as I think its in filter cycle. Am not sure on how to turn off the filter cycle. Quote Link to post Share on other sites
Laurence 0 Posted January 19 Author Report Share Posted January 19 Sorry now I am able to turn off the jets completely. I turned the temp back up and it is starting on high speed. Quote Link to post Share on other sites
Laurence 0 Posted January 19 Author Report Share Posted January 19 2 hours ago, CanadianSpaTech said: Have you recently made any changes to the spa...new pump? Place the temp down 5 degrees and wait 30 seconds or so for the pump to stop and heat light to go out. No filter cycle running. It will take about 30 seconds for the heater to cool and pump to shut off. Then turn the temp back up so heat light comes on and pump starts. Does it start in hi speed or low speed? I have attached a few pictures of the motherboard incase I have not set somthing correctly there. Quote Link to post Share on other sites
CanadianSpaTech 419 Posted January 19 Report Share Posted January 19 Has the spa run properly since you put the pump in?... or is it a new install of the pump and it has not run correctly yet. Did you remove the wires to the pump when you changed the pump? If the latter you likely have the hi speed and low speed wires backwards at the pump. With power off reverse the red and blk wires. Make sure common (white) is in correct location. 1 Quote Link to post Share on other sites
RDspaguy 632 Posted January 19 Report Share Posted January 19 That is most likely. If wired correctly, post a pic of the wiring diagram. If you replaced the board the dipswitch settings could be wrong. Quote Link to post Share on other sites
Laurence 0 Posted January 19 Author Report Share Posted January 19 Hi, managed to get it sorted. I put the low speed and high speed the wrong way when I was installing the motor. Thanks for your help and response 👍 Quote Link to post Share on other sites
Laurence 0 Posted January 19 Author Report Share Posted January 19 I was also unsure what this part ment. I have attached a photo Thanks Quote Link to post Share on other sites
RDspaguy 632 Posted January 19 Report Share Posted January 19 I was saying if the pump was not wired wrong, it could be a dipswitch issue. Quote Link to post Share on other sites
CanadianSpaTech 419 Posted January 19 Report Share Posted January 19 4 hours ago, Laurence said: I was also unsure what this part ment. I have attached a photo Thanks This table relates to the little red block with the white switches along the bottom of the circuit board. Turn power off before making any changes. You currently have A2 and A10 both ON or in the UP position. How many pumps do you have? You also have dip switches 6,7,8 in the ON position. Need to see photo of the inside cover of the pack with the schematic to know what they are for Quote Link to post Share on other sites
Laurence 0 Posted January 22 Author Report Share Posted January 22 On 1/19/2021 at 11:26 PM, CanadianSpaTech said: This table relates to the little red block with the white switches along the bottom of the circuit board. Turn power off before making any changes. You currently have A2 and A10 both ON or in the UP position. How many pumps do you have? You also have dip switches 6,7,8 in the ON position. Need to see photo of the inside cover of the pack with the schematic to know what they are for Hi, I have 2 pumps, 2 speed pump and 1 speed pump. I have attached a picture of what the definition are, am sure I have put 6,7,8 on correctly but I am not sure about 2,and 10. Thanks sorry about late reply. Quote Link to post Share on other sites
CanadianSpaTech 419 Posted January 22 Report Share Posted January 22 Looks like you are good to go. The only other thing I would verify is the Jumper Pins J11, J12, J43. See Jumper Key Section on inside cover. You could switch A2 to the down position but if everything is currently working...Enjoy Quote Link to post Share on other sites
Laurence 0 Posted January 22 Author Report Share Posted January 22 Ok thanks, what would be the difference if I changed a2 to the off position? Quote Link to post Share on other sites
