Meza Posted December 7, 2020 Report Share Posted December 7, 2020 My tub (Great Lakes Sundowner) has a floating weir but the tabs holding it down have broken off. So the weir and basket floats up out of the filter hole. Can anyone suggest how to repair this please or can you recommend what I could do? Thanks Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted December 7, 2020 Report Share Posted December 7, 2020 Do you still have the clips? If you do you could try and use a 2 part epoxy and epoxy them back in. If not perhaps cut a small slot just above where the weir sits in the collar and use a wedge of some sort but there is always the danger of the wedge falling into the filter area and past the filters and into the pump. Drill a hole through the weir and also through the collar. Use a small stainless steel screw to hold it in place. It would likely get loose over time screwing and unscrewing each time you want to clean the filters but you could always drill another hole and start again all the way around the collar each time the hole wears out. Put a rock in the basket to keep it weighed down so it doesn't float and delete the weir all together @RDspaguywhat you got...lol Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted December 7, 2020 Report Share Posted December 7, 2020 I think you covered it, buddy.👍 Otherwise, you are replacing the filter canister, which you do NOT want to do. Just to clarify, the holes and screws should not go through the collar, just into it. Quote Link to comment Share on other sites More sharing options...
jdw1222 Posted December 7, 2020 Report Share Posted December 7, 2020 good info. Exact same thing has happened to mine and i have no idea where the pieces went. my filter stays in place and seem to function fine so haven't paid it a lot of attention but will try some of the fixes mentioned Quote Link to comment Share on other sites More sharing options...
Meza Posted December 8, 2020 Author Report Share Posted December 8, 2020 Fantastic, thanks for the suggestions both. I think I'll try some screws as I don't have the broken tabs. Quote Link to comment Share on other sites More sharing options...
