zwill06 Posted October 27, 2020 Report Share Posted October 27, 2020 I have a down East spa by masterspas #1200875 and have been dealing with my spa tripping the breaker for the last 4 weeks. I initially isolated it to the heater, which was replaced last Friday. The spa then started back up without tripping the breaker, heated up and ran for about 1 day. I then came home and found that it was shut off and the breaker was tripping again. Not sure if I was sold a faulty heater? But I’m trying to figure something else out now. I used a multimeter and the heater tested within range, however I found that the breaker was not reading the correct voltage. Not sure what is going on, but any ideas would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
ratchett Posted October 27, 2020 Report Share Posted October 27, 2020 How old is the filter in your tub? How frequently do you clean it? Try removing or replacing the filter and see if that helps. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted October 27, 2020 Report Share Posted October 27, 2020 Was the whole heater assembly replaced, or just the element? Does it run for a while or trip as soon as you turn it on? Quote Link to comment Share on other sites More sharing options...
