lsaks Posted June 12, 2020 Report Share Posted June 12, 2020 Hello all! I'm new to the forum and would like to thank you in advance for your time and input. I have an older CalSpa hot tub that has the 2100 topside control panel. The control panel is flashing a zero (or O) and pressing any of the 4 buttons does nothing. I reset the hot tub, no change. I inspected the circuit board (front and back) and do not see any signs of damage. When I manually connect the pump, it works, and there is not tripping caused by the heater. Any suggestions as to what may be causing the control panel to not respond and flash the 0 (or O)? This all happened when I turned my spa on for the first time this season. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted June 12, 2020 Report Share Posted June 12, 2020 Post a pic of the circuit board so we know what you have. Quote Link to comment Share on other sites More sharing options...
lsaks Posted June 12, 2020 Author Report Share Posted June 12, 2020 Here it is, thanks! Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted June 12, 2020 Report Share Posted June 12, 2020 Not sure if this helps.... https://www.justanswer.com/pool-and-spa/98my7-cal-spa-2100-won-t-turn-on-emptied-fix.html 1 Quote Link to comment Share on other sites More sharing options...
lsaks Posted June 12, 2020 Author Report Share Posted June 12, 2020 Thank you for the link. It seems to be the same issue. I will replace the control panel and hope for the best. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted June 12, 2020 Report Share Posted June 12, 2020 Sorry couldn't be more help I don't see a lot of Cal Spa in Canada. Please post result to help the next guy. Regards 1 Quote Link to comment Share on other sites More sharing options...
lsaks Posted July 18, 2020 Author Report Share Posted July 18, 2020 Update to this issue: Finally got a replacement control panel. Once it was installed, I got the same 0 code and nothing works when pressing the buttons on the control panel. Apparently, the problem has not been resolved. Debating if it is worth changing the circuit board, because after checking the board, front and back, there is no visible damage. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted July 18, 2020 Report Share Posted July 18, 2020 http://balboadirect.com/spa-panel-messages.aspx 0 or O is not an error code on that system. I have no clue what it means. I would first test the incoming voltage to the spa. Next test the sensors with an ohm meter set to 20k ohms, they should be very close to each other. Then check the transformer output. Then unplug the vacuum switches (safety suction) if you have them. If these are all good, you need a new board. Quote Link to comment Share on other sites More sharing options...
