CalSpa Windsor 852 - Water Issues
  • Replies 91
  • Created
  • Last Reply
Top Posters In This Topic
Popular Posts
Bromine does not need or is affected by cya. Sodium bromide cannot be tested as it is not an oxidizer in that form and can only be tested once converted into bromine, which is done with oxidation
Another great bit of guidance sir. Thankyou.   Especially loved the comment "It has been reported that the average person produces about one pint of sweat during a 15-minute soak in a spa."
Hahaha! Cheers, ill keep you posted on the ahh-some treatment once its arrived along with the cheese, sorry I mean calcium 🙂
Posted Images
So confused. I read another website and it says its a complete replacement to bromine which I know is not true through learning on this forum. How do people get away with misleading information like this?
https://www.poolandspa.com/page835.htm#:~:text=The natural alternative to chlorine,safe and odor-free environment.&text=your water is percolated through,your spa to control bacteria.
Link to post
First I have heard of it. I don't use bromine, or recommend it to my customers, and have not read the nature2 instructions in many years. Apparently the bromine can react with the silver and copper ions to form a compound which renders the ions ineffective. It is no different than spa frog, which sells a bromine/mineral dual floater. Nature2 website does not discuss it, and still advertises to reduce bromine usage by 50%. I would listen to the manufacturers recommendations. I guess it is a waste to buy nature2 under those circumstances.
Mineral purifiers used with mps is approved as a sanitizer with appropriate mps residual. But this is an expensive route and mps has it's own issues including very high ph.
Once bromine or bromide is added to the water you are using a bromine maintenance system, not dichlor/bleach, even though you add chlorine as an oxidizer for the bromide. Bromine/bromide cannot be removed from the water, it must be drained to convert to chlorine or mps system.
  • Thanks 1
Link to post
From what I gather it is only a problem with high bromine levels so will be fine at the recommended .5ppm. Curious that nature2 says not to use bromine when spa frog sells a dual system. They both use the same silver and copper ions.
Link to post
I know weird right. Ill keep away from minerals with the bromine then and utilize the ahhsome on drain and refills.
These are the granules I'm using to start the tub. Labelled as bromine granules but consist of -
Sodium Dichloroisocyanurate Dihydrate - which I assume is CYA + Chlorine to oxidize the below bromide
Sodium Bromide - for my bank to be activated by bleach.
Cheers
Link to post
Dichlor, which is approximately 45% cya.
Sodium Bromide
What the dichlor oxidizes into bromine.
  • Thanks 1
Link to post
awfully odd mate. Ill keep it in mind for a later date when I understand that side better I think. I want to home in the bleach method and get rid of all those nasties. Ill do some further homework on minerals to see if it fits my bank lol
Cheers as always sir
Link to post
They are a bit pricey, but for low chemical systems they are gold. The metals, from what I understand, also will penetrate the mucous layer of the biofilm bacteria and prevent its formation.
Ozone would to, but you can't really establish an effective ozone residual in a spa to get it into all of the pipes. Being introduced as a gas, it doesn't saturate the water but bubbles out. Some manufacturers have started using various devices to cause ozone saturation, but I don't know how effective they are.
Link to post
Looks good.
Almost 13hours later
Result 7.9
Before 9.6
Burnoff 1.7 in near 13hours
So 24hours will be around 3.4per24hours I expect which I can handle until next drain, ahhsome and refill.
Yay! Thankyou so much for your tutoring sir.
Link to post
Question again.
My TDS is at 605 and I've not stepped foot in the tub, could this be excess remains from the previous ahhsome, drain and refill?
Is it the fact my TDS pen is a cheap piece of crap? Should I get one of the HM Digital ones?
At fill the TDS is 255 from the tap.
Link to post
Looking good after a week.
Slight decrease in TA.
Tds at 744ppm
Seem to be getting the slow dispenser dialled in nicely to save me having to add sodium hypochloride every day. A little on the high side at the moment for the setting and the bromine level so I'm reducing the setting on the dispenser to lower that.
Roll on the next drain and refill as i want to ahhsome the tub once more as I still think there is biofilm in this tub.
Cheers as always
Link to post
