Stillwaters123 Posted April 1, 2020 Report Share Posted April 1, 2020 Hello! My Hot Springs has stopped working. Earlier this winter I noticed the red light blinking, the power tripped at the breaker, and the water was cold. Based on online forums, I figured that it was likely clogged filters or an air bubble in the pumps. I cleaned all the filters, put a hose down the main filter to force water into the pumps, and it worked! I restarted the unit, it heated back up. All set. Now the problem has happened again however, just 2 months later. I reset the power at the breaker, cleaned out the filters, and put the hose down the main filter. When the hose was in the filter, I could turn on the pumps and everything was working fine, for more than 10 minutes. Unfortunately, when the tub was full and I removed the hose, the pumps would run for a bit, then after about :60 seconds the pumps would stop, the breaker would trip, and the light flashes red. I tried multiple times (reset the breaker, run the pumps, would work for about :60 seconds, then trip the breaker and red light flashes.) I also removed all of our filters and tried to run this, just to make sure that the problem wasn't dirty filters, and the same thing happened. Any suggestions on what I should do next? I've been following the forums but I don't see any suggestions after the steps I took above. Thanks! Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted April 1, 2020 Report Share Posted April 1, 2020 Sounds like your circulation pump is out. Quote Link to comment Share on other sites More sharing options...
Stillwaters123 Posted April 2, 2020 Author Report Share Posted April 2, 2020 Thanks! That's what I was thinking. I've watched a few videos and it looks pretty straight forward to replace. Anything tricky or unexpected I might need to know before I give it a try? Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted April 2, 2020 Report Share Posted April 2, 2020 Not much to it. Changing the cord can be a PITA, so get the right one for your spa. Quote Link to comment Share on other sites More sharing options...
Stillwaters123 Posted April 3, 2020 Author Report Share Posted April 3, 2020 Thanks so much! Quote Link to comment Share on other sites More sharing options...
