Steve3 Posted May 5, 2018 Report Share Posted May 5, 2018 My caldera niagra hot tub ran without issue for about 10 years. I have a GFCI sub panel with a breaker for pumps and a breaker for heat. One day my kids noticed a slight buzzing tingle feeling when in the water and touching someone outside the water (ground path I assume). When they showed me I freaked like Sherrif Brody “everybody out of the water”. It was a minor “nine volt battery on the tongue” type tingle and the breakers did not trip. I emptied the water and shut it down in hopes to repair it. I unfortunately did not see if it was caused by the pump circuits or the heater circuit but I suppose I still can if I fill it, except I don’t want to actually stick my hand in the water to test. Anyway the first thing I noticed was the ozoneator tubing from the ozone to the water line was rotted away at the ozone box. It resembled that of like copper oxidation with a crumbly blueish color. Could this be it? So what’s my best direction to go? Shotgun parts? Hiring electrician? Buy new hot tub? Any all all recommendations welcome. Thanks steve Quote Link to comment Share on other sites More sharing options...
castletonia Posted May 5, 2018 Report Share Posted May 5, 2018 I would start with an electrician or hot tub service tech. I am not either, but my guess would be heater or loose connection somewhere. Obviously if you can afford to and want a new hot tub, then that is always an option but assuming you like the Niagara, you are looking at around $12k+ to replace. Quote Link to comment Share on other sites More sharing options...
Jersey Hot Tub Repair Posted May 5, 2018 Report Share Posted May 5, 2018 If you get a tingle when you step on the ground, current is leaking from a component into the water. Does the TEST button on the GFCI work? I'd be concerned with a hot tub that produced a tingle without causing the GFCI to trip. I'd start with an electrician checking that out. I wouldn't let my children get near that tub until you found the cause of the problem and get it fixed. Today's tingle may be tomorrow's electrocution. Dave Quote Link to comment Share on other sites More sharing options...
