Lindsey79 Posted December 12, 2010 Report Share Posted December 12, 2010 I have a spa that uses a bromine system (many thanks to Waterbear's step-by-step directions on the 3-step bromine start-up --- that was very, very helpful!). After reading through so many threads on this forum, I have a question of my own. I've seen many references to "dry acid" to reduce pH. I've just used something called "pH decreaser", but now I'm starting to pay far more attention to the actual chemicals. Mine is sodium bisulfate. Is this the same as dry acid? Is the ideal chemical to decrease pH? If not, what are other suggestions? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
quantumchromodynamics Posted December 12, 2010 Report Share Posted December 12, 2010 Mine is sodium bisulfate. Is this the same as dry acid? Is the ideal chemical to decrease pH? If not, what are other suggestions? Thanks in advance! Yes, sodium bisulfate is dry acid. It works fine. However, I prefer 31.45 % muriatic acid (hydrochloric acid). You can get a quart at any hardware store. Quote Link to comment Share on other sites More sharing options...
waterbear Posted December 12, 2010 Report Share Posted December 12, 2010 If your tub is 400 gal or less then using sodium bisulfate might be easier than using muriatic acid since such small quantities are required. The dry acid is easier to measure in small quantities than the liquid muriatic acid, IMHO. Otherwise, I agree that muriatic is preferable. Quote Link to comment Share on other sites More sharing options...
Lindsey79 Posted December 12, 2010 Author Report Share Posted December 12, 2010 If your tub is 400 gal or less then using sodium bisulfate might be easier than using muriatic acid since such small quantities are required. The dry acid is easier to measure in small quantities than the liquid muriatic acid, IMHO. Otherwise, I agree that muriatic is preferable. It is a smaller tub -- only 375 gallons. But thank you for differentiating between sodium bisulfate and muriatic acid and just letting me know that I can pick it up at any hardware store. Trying to translate "pool products" has proven to be more difficult than I anticipated and I really appreciate all the real life translations/alternative (baking soda, borax, etc.). Much thanks to you both! Quote Link to comment Share on other sites More sharing options...
spawn Posted December 12, 2010 Report Share Posted December 12, 2010 I picked up a pool size (7 lbs) bottle of dry acid (pH minus) at Lowes (they have pool chemicals in their garden section) for a very low price (can't remember how much - <$10?). I put in a couple of TBSP every two or three weeks because of PH creep. I also use it when I balance the tub after a fill because I start with high PH from the tap. Quote Link to comment Share on other sites More sharing options...
