kaseykent Posted July 28, 2010 Report Share Posted July 28, 2010 Does anyone have any experience with Pristine Blue? What do you think of it? This person recently converted from Soft Soak and now has some green water, wondering if they made the right decision to switch. I am sure any help would be appreciated. This topic was started in another hot tub forum, but I am trying to find some answers, feel free to reply in either forum. The post was originally started here. Quote Link to comment Share on other sites More sharing options...
waterbear Posted July 28, 2010 Report Share Posted July 28, 2010 Does anyone have any experience with Pristine Blue? What do you think of it? This person recently converted from Soft Soak and now has some green water, wondering if they made the right decision to switch. I am sure any help would be appreciated. This topic was started in another hot tub forum, but I am trying to find some answers, feel free to reply in either forum. The post was originally started here. From biguanide to copper...out of the frying pan into the fire! Soft Soak(bigaunide) is an EPA residual sanitizer. Pristine Blue is NOT. (their EPA registration number is for the copper sulfate it contains. Copper Sulfate is an algaecide. It's kill times are way too long to be an effective sanitizer in a hot tub! Clear water is not alwasy safe water. Green water in this case either is from the addition of chlorine with some Soft Soak still present (did they replace their filters when they switched and completely drain and refill?) Pristine blue IS used with chlorine and chlorine and Soft Soak or any other biguanide based system are NOT compatible. MPS, the other oxidizer used with Pristine Blue, is also not compatible with biguanide. Green could also come from overdosing on copper from the PristineBlue. It can color the water green, stain the tub, and stain hair and nails green. Yep, green hair is caused by copper, period! Pristine Blue IS copper, period! "nuff said? However, I do not feel that the green was a copper overdose in this case. I strongly suspect that when the switch was made to Pristine Blue the biguanide was not completely destroyed in the tub first A drain and fill is not sufficient. The Tub needs to be oxidized completely to burn of any remaining residual in the plumbing and the filter needs to be discarded and replaced with a new one since the biguanide residue in the filter cannot be removed. When Pristine Blue is started up one of the steps is oxidizing the tub with PristineExtra, which is chlorine. I suspect that the oxidizer oxidized the remaining biguanide and turned it green (which is what color it turns when oxidized, as anyone who has properly converted to a biguanide system to a halogen based sanitizer system can attest to! Pristine Blue IS a halogen based system, BTW! It is NOT chlorine free by any stretch of the imagination!) The Pristine Blue system has two different oxidizers. PristineExtra is just dichlor, the most common form of chlorine used in hot tubs and PristinePower is just MPS, the standard non chlorine oxidizer or shock used in hot tubs. Pristine Blue is chelated copper sulfate, nothing more than oridinary copper algaecide. Can anyone say ripoff? My suggesting is to dump the pristine blue and use either chlorine or bromine in the tub. Quote Link to comment Share on other sites More sharing options...
kaseykent Posted July 29, 2010 Author Report Share Posted July 29, 2010 Thanks waterbear! I will let the Pristine user know what your thoughts are. Quote Link to comment Share on other sites More sharing options...
waterbear Posted July 29, 2010 Report Share Posted July 29, 2010 Thanks waterbear! I will let the Pristine user know what your thoughts are. And I guess there is ANOTHER forum I need to join! (noticed you were an admin). Quote Link to comment Share on other sites More sharing options...
