Rich D. Posted July 26, 2010 Report Share Posted July 26, 2010 Hello and help please, I replaced my current Clormatic generator today because the cell went bad and the replacement cell for my unit cost from $500-1000. I purchased a Hayward Swim Pure Plus which is very similar to the Clormatic but replacement cells are only $250. The plumbing went problem free and tested fine. My problem is with the electrical hook-up. There are only 3 wires in the harness that came with the new unit - red, black & green. The green ground wire was easy. There are 4 terminals where the red & black can hook up. There were 2 jumpers installed across terminals #2 & #3. The diagram in the supplied manual said that for 120 VAC operation to move the jumpers to #1 & #2 and to #3 & #4. It showed the red & black feed wires to be hooked to terminal #1 & #4. This is how I hooked up my wires but when I turned the power back on I had a huge spark and a flash at terminals 1 through 4 and it left black soot in the area. I am worried about calling Hayward or Specialty Pool Products (purchased from S.P.P.) as I caused this myself. Just bought the unit 2 months ago but since I installed it myself I may have voided the warranty. Any help or suggestions would be appreciated. I had planned on paying someone to install it but my wife wanted to save the $125. and twisted my arm. Thanks, Richie D. Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted July 26, 2010 Report Share Posted July 26, 2010 Post a pic of your hookup, and we will see what went wrong hopefully. Quote Link to comment Share on other sites More sharing options...
pooltech9 Posted July 26, 2010 Report Share Posted July 26, 2010 Check youu incoming voltage. This is typical of what happens when the jumpers are configured for 120v and you run 240v. Quote Link to comment Share on other sites More sharing options...
Dustin Golden Posted July 26, 2010 Report Share Posted July 26, 2010 i would appreciate if you could show us some images for the same so that it may become easy for us to make out the problem by the helpful by the pictures. By the time you may just check out your voltage. Quote Link to comment Share on other sites More sharing options...
Rich D. Posted July 26, 2010 Author Report Share Posted July 26, 2010 Post a pic of your hookup, and we will see what went wrong hopefully. Quote Link to comment Share on other sites More sharing options...
Rich D. Posted July 26, 2010 Author Report Share Posted July 26, 2010 I will try to post pics tonight thanks. Quote Link to comment Share on other sites More sharing options...
Rich D. Posted July 27, 2010 Author Report Share Posted July 27, 2010 Post a pic of your hookup, and we will see what went wrong hopefully. Quote Link to comment Share on other sites More sharing options...
Rich D. Posted July 27, 2010 Author Report Share Posted July 27, 2010 Having issues attaching my photos. I will have to abort unless I can e-mail them to you. Richie Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted July 27, 2010 Report Share Posted July 27, 2010 Photobucket is a service that works good with this forum. http://photobucket.com/ Quote Link to comment Share on other sites More sharing options...
Rich D. Posted July 27, 2010 Author Report Share Posted July 27, 2010 Thanks Pool Clown - hope this works for you. Richie Quote Link to comment Share on other sites More sharing options...
Rich D. Posted July 27, 2010 Author Report Share Posted July 27, 2010 I should mention that in the photo of the timer the red & black wires coming from the Swimpure are currently not attached and are pushed aside in the botom of the timer box. I had the red wire attached terminal #5 to the far right and the black wire attached to terminal #3 in the middle. These are the terminals that my Clormatic system were attached to. Richie Quote Link to comment Share on other sites More sharing options...
Rich D. Posted July 27, 2010 Author Report Share Posted July 27, 2010 Thanks Spa Guru for the Photobucket link. Very easy to use. Richie Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted July 27, 2010 Report Share Posted July 27, 2010 It looks like you have a 220V system. If the timeclock is keeping time, its 220V. Have you tested the 1 and 3 terminals on the time clock? (the ones with the white wires connected to). I believe you will get 220V there and thats your problem. It appears you set up the unit for 110V and your feeding 220V to it. Quote Link to comment Share on other sites More sharing options...
Rich D. Posted July 27, 2010 Author Report Share Posted July 27, 2010 That sounds logical.I will check the voltage tonight. In the mean time I am guessing that I did some damage to this unit and am wondering what my next step should be.I was thinking that I should contact Specialty Pool Products 1st and tell them that the unit will not turn on at all and see what they suggest.I am trying to fix my wrong without having to purchase a whole new unit.I believe that if I tell them that I hooked it up to 220 that this may void any chance for my warranty to cover this, especially since a licensed electrician was not used. Any thoughts on this ? Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted July 27, 2010 Report Share Posted July 27, 2010 If you damage the unit, it will probably show. So your'e best off to correct the voltage problem and try to start it again, Before calling. Quote Link to comment Share on other sites More sharing options...
Rich D. Posted July 28, 2010 Author Report Share Posted July 28, 2010 Well I just finished running through the voltage tests and you were both correct, the voltage coming out of the timer was 220v so I moved the jumpers back to the original setting for 220v which was across terminals #2 & #3 and reconnected my red & black wires to the timer.When I flipped the breaker back on I really did not to expect the unit to power up but it turned on and I ran through all of the settings and tests and everything seems to be working fine. I am extremely happy that this turned out positive and want to thank you both for your help and time with this.Your knowledge is invaluable and I will be sure to use your services again in the future and to also recommend to others. Thanks again for everything, Richie Quote Link to comment Share on other sites More sharing options...
pooltech9 Posted July 28, 2010 Report Share Posted July 28, 2010 You will need to purchase a GLX-PCB-RITE. You have fried your board and it is evident that you wired it wrong. When you put the new board in, do not move the jumpers on the wiring terminals, bring the 220v into terminals 1 and 4. Quote Link to comment Share on other sites More sharing options...
Rich D. Posted July 28, 2010 Author Report Share Posted July 28, 2010 So even though everything appears to be working fine you still feel that I should still replace the circuit board ? I see these curently selling on ebay for approx. $185-$200. Please advise....... Richie Quote Link to comment Share on other sites More sharing options...
pooltech9 Posted July 29, 2010 Report Share Posted July 29, 2010 Seems like you got lucky. If it ain't broke, don't fix it! Quote Link to comment Share on other sites More sharing options...
