GoodGirl Posted May 13, 2010 Report Share Posted May 13, 2010 Hi everyone, I have a Hayward H400 IDPL2 heater - it is propane and low nox. This is my 3rd season with it. When we started our pool we noticed that the heater will cycle on, try 3 times, and then give a IF (ignition failure) code. I have checked all the wiring, we DO smell gas when it goes to fire, and it will cycle and then we hear a "click" but we don't get the "woompf" when the heater should ignite. i tried twice a day for a week, thinking their might me air in the gas line. Nothing. My pool company is telling me it is probably a gas valve (cheapest I found was $116 they are at 350!) or a Control module (about $300 I didn't even ask their price!). It has not been cleaned since we bought it. There are a few spiders and webs in there. Also, we live in SE PA and had A TON of snow this winter...don't know if that plays into it at all!) Any thoughts would be greatly appreciated! I would love to get it running soon - and I am willing to buy the parts online if you guys tell me I can put them in myself! Any and all help would be greatly appreciated! Kristen Quote Link to comment Share on other sites More sharing options...
ny poolguy Posted May 14, 2010 Report Share Posted May 14, 2010 More they likely the spider webs are clogging one or more of the gas orifices. At least the one for the burner the hot surface ignitor sits over. Bend a paperclip open making it look like the letter J and use that to clean out the orifices(with the heater off). They are the five little nipples on the gas rail in front of the burner tubes. That's the problem or the the hot surface ignitor is bad. It's located over the center burner. Ether way the flame sensor is not sensing a flame and it's locking out giving the IF code. Quote Link to comment Share on other sites More sharing options...
ny poolguy Posted May 14, 2010 Report Share Posted May 14, 2010 Just a little advice. Put the door back on before trying to fire the heater or at very least don't kneel directly in front of it. Nobody looks good with singed eyebrows and eyelashes! Quote Link to comment Share on other sites More sharing options...
GoodGirl Posted May 14, 2010 Author Report Share Posted May 14, 2010 NY Poolguy THANK YOU! Took 5 minutes, and fired up like a champ! Now, I can hit the hot tub tonight! Thank you so much, saved me a TON! Quote Link to comment Share on other sites More sharing options...
ny poolguy Posted May 15, 2010 Report Share Posted May 15, 2010 NY Poolguy THANK YOU! Took 5 minutes, and fired up like a champ! Now, I can hit the hot tub tonight! Thank you so much, saved me a TON! No problem,I'll send you a bill Quote Link to comment Share on other sites More sharing options...
TheEngine Posted February 13, 2011 Report Share Posted February 13, 2011 After doing some review research on the above same issue (I noticed my heater was firing up and than going out (with all the symptoms above)). I just tried the paper clip on all 7-8 nipples and it worked just great. It took me 2 minutes. Thanks a million (at least a service trip cost!). Quote Link to comment Share on other sites More sharing options...
GoodGirl Posted May 10, 2011 Author Report Share Posted May 10, 2011 Hi guys, Kristen again, last year I did the paper clip trick and it worked like a champ, but no luck this year. I tried the paperclip, and a pipe cleaner. No luck. Any other suggestions out there? It does cycle on, and I hear the click right before ignition - but no ignition. Wondering if there is anything else to clean out? Or do I need parts? And if I do need parts = where do I start?? Thanks!!! Quote Link to comment Share on other sites More sharing options...
pooltech9 Posted May 11, 2011 Report Share Posted May 11, 2011 The problem is probably the spiders again. You should have taken the gas orifice out completely and cleared the web out. Use a 7/16" wrench and take them off to clear them. Poking with a paper clip will only make a small hole and knock debris into the gas manifold, which will eventually make it's way back to clog up again. Be careful not to cross-thread the orifices when you put them back in. Before you do anything make sure your propane tank is full or at least 30-40%. Quote Link to comment Share on other sites More sharing options...
GoodGirl Posted May 14, 2011 Author Report Share Posted May 14, 2011 Thanks - I will try that when the rain stops! I also ordered an ignitor for it - so I might try the ignitor before I take everything apart. Is there any way to keep the spiders out of there? Can you remove it and store it when not in use or is that not a good idea?? Quote Link to comment Share on other sites More sharing options...
props4you Posted May 26, 2011 Report Share Posted May 26, 2011 Thanks - I will try that when the rain stops! I also ordered an ignitor for it - so I might try the ignitor before I take everything apart. Is there any way to keep the spiders out of there? Can you remove it and store it when not in use or is that not a good idea?? I've got the same problem.. A friend told me to put a small cup of mothballs in the cabinet to keep the spiders away. I cleaned all the orifices on the manifold and the burner tubes. No luck! Unit cycles and calls for gas and gas goes on. I see the ignitor glow. Whats next? Quote Link to comment Share on other sites More sharing options...
