andob45 Posted April 13, 2010 Report Share Posted April 13, 2010 Looking for some help, have an 02 sundance Cameo, just had a temp sensor installed. spa was in watchdog, reset power temp read 113, water was ice cold. replaced temp sensor. water heated up spa is functioning all automated functions but my topside control is not operating properly. most of the buttons do not function. the jets 2 button turns the pump on also switches the mode, and adjust s the temp up. jets 1 button sets the temp down and turns the pump on. the jets two button also turns the light on. all other buttons are non functioning. the spa is maintaing temperature. any Ideas much appreciated. Quote Link to comment Share on other sites More sharing options...
Peteyboy Posted April 13, 2010 Report Share Posted April 13, 2010 I'm not positive but it sounds like a faulty topside. You can unhook some loads such as the light and ozone, then reset the power and see what happens. Quote Link to comment Share on other sites More sharing options...
JAMES THE HOT TUB GUY Posted May 5, 2010 Report Share Posted May 5, 2010 I'm not positive but it sounds like a faulty topside. You can unhook some loads such as the light and ozone, then reset the power and see what happens. Un hooking the lights and ozone will not help the situation what you need to do is un hook the remote that is on the back side of the spa they are known to go bad it uplugs from the grey ribbon cable located in your load box. if this does not fix it then it is a bad top side. Quote Link to comment Share on other sites More sharing options...
