sscott0203 Posted November 19, 2009 Report Share Posted November 19, 2009 I have searched everywhere and kind find a straight answer. Can i use sch 40 pvc fittings from Lowes for my hot tub. I had to re-plumb for my new spa pack. Anyone have the correct answer? Quote Link to comment Share on other sites More sharing options...
quantumchromodynamics Posted November 19, 2009 Report Share Posted November 19, 2009 PVC Schedule 40 pipe and fittings is intended for pressure applications where the operating temperature will not exceed 140 ° F. http://www.charlottepipe.com/Default.aspx?...mp;type=PVCCPVC CPVC Schedule 80 pipe and Schedule 80 fittings system is intended for pressure applications where the operating temperature will not exceed 200 ° F. http://www.charlottepipe.com/Default.aspx?...mp;type=PVCCPVC Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted November 19, 2009 Report Share Posted November 19, 2009 Yes, schedule 40 fittings will work just fine. Quote Link to comment Share on other sites More sharing options...
sscott0203 Posted November 19, 2009 Author Report Share Posted November 19, 2009 Thanks, all the ones i bought are made by Lasco though. Quote Link to comment Share on other sites More sharing options...
quantumchromodynamics Posted November 19, 2009 Report Share Posted November 19, 2009 Max Operating Temperature (�F) 140 http://www.lascofittings.com/SupportCenter...lProperties.asp The answer is: Yes, the schedule 40 will work just fine. If you are using flex pipe, I recommend that you allow the glue 8 hours to set before pressurizing. Quote Link to comment Share on other sites More sharing options...
sscott0203 Posted November 20, 2009 Author Report Share Posted November 20, 2009 Thank you very much for the reply and help Quote Link to comment Share on other sites More sharing options...
sscott0203 Posted November 20, 2009 Author Report Share Posted November 20, 2009 thanks very much Quote Link to comment Share on other sites More sharing options...
Roger Posted November 20, 2009 Report Share Posted November 20, 2009 Thanks, all the ones i bought are made by Lasco though. Lasco is OK. They are not high end fitting manufacturers but they make a fine product. Quote Link to comment Share on other sites More sharing options...
