How Often Do You Shock?
fabio_22
How often do you SHOCK?
11 members have voted
  1. 1. Just curious
    • BEFORE each use
    • AFTER each use
    • Daily
    • Twice a week
    • Once a week
      6
    • Never
      2
    • Other
      3
I've heard mixed opinions on this... just curious.......
I shock when my combined chlorine approaches 1ppm....Which by the way is almost never...only after a big party and lots of tub usage.
I keep my free chlorine between 1ppm to 5ppm at all times.
I have found the day of the week has no bearing on the needs of my water. ;)
Other: As needed.
If I am going to be away during the week, I will shock once (typically 2oz of MPS) to reactivate my Bromine reserve and keep my sanitizer level above 1ppm a day-or-two beyond when I expect to return.
If I am at home, I "target" my sanitizer level at 1ppm (+/- 0.5ppm) which requires smaller "shocks" one or two times per week (typically 0.5-1.0oz of MPS after spa use).
In my case...spa use, Bromine demand and my target sanitizer level dictates when I shock vs. a set time interval.
Note: Although not recommended, I have had no water issues keeping my spa at a 0.5-1.0ppm sanitizer level using a Spa Frog bromine/mineral floater and 1hr-every-12hrs filtration (half the minimum recommended amount).
I use Nitro's Dichlor/Bleach method. I only shock if I've let the chlorine get too low and the water gets cloudy. That hasn't happened with the current fill and I'm going on 6 months.
Dave
Chlorine and Bromine are two different animals. Bromine needs to be shocked for a different reason then Chlorine. i.e. to convert spent Bromine back to usable Bromine.
I add ("Shock" whatever you want to call it) enough Chlorine (after soaks and/or 2-3 times per week) to ALWAYS maintain some Free Chlorine in the tub, and to keep my Chlorine Demand low. Do that and you will never have sanitation problems.
I use Nitro's dichlor-then-bleach method and am on day 90 of my current fill. I add bleach and/or mps after each soak according to chem geek's rule of thumb. Combined chlorine is consistantly zero or very close to zero. I have never shocked beyond the regular per soak maintenance dosage.
