Kmurray24 Posted June 24, 2009 Report Share Posted June 24, 2009 Hi, I'm having a new 18x36 pool and I'm thinking about what I might need for electric outlets. I was basically thinking I should have 2 outlets at each end of the pool. I was thinking I might need a fan at each end to run a fan and maybe some music. I'll also need some low voltage light along the perimiter. Would that be separate? Any other suggestions? Is it expensive and should I get quotes? THanks Quote Link to comment Share on other sites More sharing options...
Seahunt Posted June 24, 2009 Report Share Posted June 24, 2009 Hi, I'm having a new 18x36 pool and I'm thinking about what I might need for electric outlets. I was basically thinking I should have 2 outlets at each end of the pool. I was thinking I might need a fan at each end to run a fan and maybe some music. I'll also need some low voltage light along the perimiter. Would that be separate? Any other suggestions? Is it expensive and should I get quotes? THanks If it is a new pool and they have not laid the electric yet, yes, it's a good idea to have extra lines put in. I had them put one in and they only charged me $100. It would be very expensive to do after the fact. Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted June 24, 2009 Report Share Posted June 24, 2009 Check local codes. Some areas Require an outlet within a certain distance from waters edge. Quote Link to comment Share on other sites More sharing options...
