jjfromtheburgh Posted April 2, 2009 Report Share Posted April 2, 2009 Can someone recommend where I can purchase a new motor for my spa pump? It's a two speed, 5HP motor. I would like for it to be from a reliable online source and not some fly by night operation. Quote Link to comment Share on other sites More sharing options...
Pathfinder Posted April 2, 2009 Report Share Posted April 2, 2009 What kind of tub or what brand is the current motor? This info is kinda important. Quote Link to comment Share on other sites More sharing options...
jjfromtheburgh Posted April 2, 2009 Author Report Share Posted April 2, 2009 I have a 450 gal gulf coast spa. Gulf Coast is out of biz so i have to purchase one on my own. The manufacturer of the motor is Marathon. What concerns me about ordering another Marathon motor is that this one is only 9 mos old. This will be the second motor i had to replace. The first one went bad within 6 mos. I took a picture of it but don't know how to post it here. Quote Link to comment Share on other sites More sharing options...
ps558 Posted April 2, 2009 Report Share Posted April 2, 2009 I have a 450 gal gulf coast spa. Gulf Coast is out of biz so i have to purchase one on my own. The manufacturer of the motor is Marathon. What concerns me about ordering another Marathon motor is that this one is only 9 mos old. This will be the second motor i had to replace. The first one went bad within 6 mos. I took a picture of it but don't know how to post it here. here is a link to some Vico product pumps http://www.spacare.com/vicospapumps.aspx It may help figure out what you need. I do not know anything about these retailers http://www.google.com/products?q=vico+spa+...=1&ct=title The one thing you have to watch about some online pumps is some places put the wet end on a motor for you, which is OK just that a pre assembled pump from Vico or Aqua flo has a longer warranty. Vico products are made Balboa Water Group and Aqua Flo by Gecko. You also will need to know what size pipe you have, I am guessing at 2 inch because of the HP rating and that is almost the norm for newer spas. Also look at the motor name plate to match up the correct voltage and amps. Since spa pumps can be relabelled if you amp rating is 3.5/12 and the HP rating has ---- on the lablel it is probally on a 3 hp Quote Link to comment Share on other sites More sharing options...
soakerguy Posted April 2, 2009 Report Share Posted April 2, 2009 I would call 1-8 7 7 - 5 3 0 - P A R T S http://www.hottubparts.com/ and i think they will have the gulf coast spa parts you are looking for. I have orderd from them and that are competent and reliable to order from. They knew the exact replacement parts I needed For my Hydrospa and even told me how to install the parts! I would call and ask about the Gulf Coast spa parts and see if they deal with them. Quote Link to comment Share on other sites More sharing options...
otis_skywalker Posted April 3, 2009 Report Share Posted April 3, 2009 Sounds to me like you got other issues going on, There's no reason to toast 2 pumps in nine months... You might want to check the line voltage going to the spa, If it's low you'll just keep having issues. btw, What part of the burgh you from? Quote Link to comment Share on other sites More sharing options...
