ssiem37 Posted February 9, 2008 Report Share Posted February 9, 2008 Is there any explanation (other than the heater's crapped out) for my water not being hot? Quote Link to comment Share on other sites More sharing options...
Pathfinder Posted February 9, 2008 Report Share Posted February 9, 2008 Your tub could be running in economy mode Quote Link to comment Share on other sites More sharing options...
Low IQ Posted February 9, 2008 Report Share Posted February 9, 2008 Sorry. Anyways what I read there was that low heat can sometimes be caused by having a clogged filter and to try running it for a few hours without the filter. If heat returns then that mite been the cause. Quote Link to comment Share on other sites More sharing options...
Dr. Spa Posted February 9, 2008 Report Share Posted February 9, 2008 Low water level Dirty filter Bad thermostat Bad pressure switch Bad flow switch Fuse blown Bad circuit breaker Bad GFCI Faulty circuit board Faulty relay Bad heating element Burnt wire Broken pump Clogged impeller Probably more,. I couldn't come up with during this 15 seconds Quote Link to comment Share on other sites More sharing options...
nsin Posted February 12, 2008 Report Share Posted February 12, 2008 ^ great sugestions, you forgot hi-limit trip Quote Link to comment Share on other sites More sharing options...
ssiem37 Posted February 22, 2008 Author Report Share Posted February 22, 2008 Low water level Dirty filter Bad thermostat Bad pressure switch Bad flow switch Fuse blown Bad circuit breaker Bad GFCI Faulty circuit board Faulty relay Bad heating element Burnt wire Broken pump Clogged impeller Probably more,. I couldn't come up with during this 15 seconds it's a bad circuit board. I'm so annoyed b/c i've had the tub five years and three months. the warranty is only five years. :cuss Quote Link to comment Share on other sites More sharing options...
spatech (the unreal one) Posted February 22, 2008 Report Share Posted February 22, 2008 it's a bad circuit board. I'm so annoyed b/c i've had the tub five years and three months. the warranty is only five years. :cuss Yeah that stinks but what can you do. Quote Link to comment Share on other sites More sharing options...
Chas Posted February 22, 2008 Report Share Posted February 22, 2008 What make and model tub do you have? Quote Link to comment Share on other sites More sharing options...
ssiem37 Posted February 25, 2008 Author Report Share Posted February 25, 2008 What make and model tub do you have? Tiger River - Bengal Quote Link to comment Share on other sites More sharing options...
soakerman Posted February 25, 2008 Report Share Posted February 25, 2008 What make and model tub do you have? Tiger River - Bengal thats a expensive part to go out so soon, i would try to get warranty coverage through watkins since it was so close to the warranty date. It is to early to have that expensive of a spa crap out. good luck! Quote Link to comment Share on other sites More sharing options...
thestallion Posted February 25, 2008 Report Share Posted February 25, 2008 What make and model tub do you have? Tiger River - Bengal thats a expensive part to go out so soon, i would try to get warranty coverage through watkins since it was so close to the warranty date. It is to early to have that expensive of a spa crap out. good luck! Really Soaker, Please tell us how much does this tub noramlly sell for? Quote Link to comment Share on other sites More sharing options...
