sassygirl Posted November 25, 2007 Report Share Posted November 25, 2007 Hi, will non-chlorine shock reduce the amount of chlorine that you have in the tub? Quote Link to comment Share on other sites More sharing options...
waterbear Posted November 25, 2007 Report Share Posted November 25, 2007 If you mean MPS, the most common kind, no. If you mean sodium percarbonate, which is rare but used in certain circumstances, yes. Either kind will test as combined chlorine on testing unless special reagents to remove the interference are used, however. Quote Link to comment Share on other sites More sharing options...
chem geek Posted November 26, 2007 Report Share Posted November 26, 2007 watebear is correct that with MPS there is not an immediate drop in chlorine levels -- that is, they do not interact with each other. However, if you use MPS on a regular basis then you may find that you don't need to add as much chlorine over time since the MPS will be oxidizing the organics instead of chlorine performing that function. Richard Quote Link to comment Share on other sites More sharing options...
waterbear Posted November 26, 2007 Report Share Posted November 26, 2007 just to clarify on what Chemgeek said... using MPS does not allow you to run a lower FC residual but with continued use of MPS you might need less chlorine to achieve the same FC residual in the water. Quote Link to comment Share on other sites More sharing options...
tony Posted November 26, 2007 Report Share Posted November 26, 2007 just to clarify on what Chemgeek said... using MPS does not allow you to run a lower FC residual but with continued use of MPS you might need less chlorine to achieve the same FC residual in the water. This is exactly what I have experienced since switching from a chlorine shock. Quote Link to comment Share on other sites More sharing options...
