Mustard Algae Wont Go Away
we have lowered our ph and alk - all our numbers "read" good. We have done the Shock and Banish treatment twice and the mustard algae goes away, the water looks great but then 1-2 days later it comes back! Why wont it say away. what can we do?
What are your numbers? (FC, TC, pH, ALK, CH, and CYA) specifically what is your CYA level and where do you normally keep the FC at? IF you have high levels of stabillizer in the water then you need to run your FC higher to compensate for the chlorine being 'stabilized' and not leaving enough to actually kill the algae.
  • 1 month later...
Algae feeds off phosphates. Buy a chemical to reduce or get rid of the phosphates in the pool. super chlorinate and add some yellow out over the area and brush off if it has reappeared, than add phosfree by natural chemistry.
BOGUS!!!!!!!
Phosphates MIGHT be a cause of repeated algae blooms but are ususlly NOT the limiing factor. Algae also feed off of nitrogen compounds and these are far more commen in poosl than phosphates (where do you think chloramines come from?) IF you have no nitrogen compounds in the pool AND have high phosphates then reducing the phosphate might work but this is ususlly NOT the case!
