Power and ready lights flashing together is indicator of circ pump flow issue. The pressure switch built into heater is not closing. Could be dirty filter, weak circ pump or bad pressure switch.Also verify the check valve opens and closes with jet pump operation. Remove filter from hot tub and see if the heater light on circuit board comes on. The pump looks like the original and even though it is moving water its flow is reduced and won't close pressure switch. Test the switch by removing connector from board with multimeter set to continuity.
