saluki17 Posted November 3, 2007 Report Share Posted November 3, 2007 I have a 18 month old Nordic Escape that has been working fine, until recently. Now, the number 115 keeps flashing on the control panel and the jets don't work at all. Is that an error code of some kind? Anyone have any suggestions as to what might be the cause and the solution? Quote Link to comment Share on other sites More sharing options...
kengorman Posted November 3, 2007 Report Share Posted November 3, 2007 I have a 18 month old Nordic Escape that has been working fine, until recently. Now, the number 115 keeps flashing on the control panel and the jets don't work at all. Is that an error code of some kind? Anyone have any suggestions as to what might be the cause and the solution? If your Nordic Escape has a Gecko control pack (which I'm assuming it does), then the flashing 115 indicates that the spa is overheating. The 115 indicates the temperature. Gecko control packs indicate an overheat condition when the temperature exceeds 112 degF. The cause of your overheat problems could be any number of things, including: a stuck heater relay, dirty or clogged filters, causing a flow problem, or defective temperature sensor. I found an on-line trouble-shooting flow-chart which specifically addresses flashing temperature displays on Gecko equipped spas. It can be found here. HTH, Ken Quote Link to comment Share on other sites More sharing options...
