Marci Posted December 31, 2009 Report Share Posted December 31, 2009 Glad you were able to resolve this. Thanks again Pool Clown, You were exactly right. I just got the new valve diverter itself in after driving across town in rush hour . Everything is back to normal and my psi is back down to 10. Now its time to relax. Have a great New Year 2010! Quote Link to comment Share on other sites More sharing options...
jbcarlson Posted January 17, 2010 Report Share Posted January 17, 2010 Pool Clown, I was able to fix the problem! Thank you very much! Can you please give me your email address so that I may send you a small thank you gift? If you don't want to post it here, please visit my website and reach out to me that way: brentcarlson.com Thanks again! Brent Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted January 17, 2010 Report Share Posted January 17, 2010 You can PM me. Quote Link to comment Share on other sites More sharing options...
WalkerPools Posted February 17, 2010 Report Share Posted February 17, 2010 I am having the same problem. I have an elevated spa that drains down to the level of the pool each night. On the return side are two jandy check valves, one as it exits the heater and one after the jandy valve used to switch from pool to spa return. Is it possible I need to replace both of them. I replaced one of them and the problem was not fixed so I switched check valve to the where the other check valve is located and the spa is still draining. Is there any other problem I could be having. Thank You. Adam Quote Link to comment Share on other sites More sharing options...
jbcarlson Posted February 18, 2010 Report Share Posted February 18, 2010 You can PM me. Sorry, just seeing your post from Jan 17, Pool Clown. What does "PM me" mean? Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted February 18, 2010 Report Share Posted February 18, 2010 I am having the same problem. I have an elevated spa that drains down to the level of the pool each night. On the return side are two jandy check valves, one as it exits the heater and one after the jandy valve used to switch from pool to spa return. Is it possible I need to replace both of them. I replaced one of them and the problem was not fixed so I switched check valve to the where the other check valve is located and the spa is still draining. Is there any other problem I could be having. Thank You. Adam You too could have the same problem as jbcarlson read this thread to diagnose. Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted February 18, 2010 Report Share Posted February 18, 2010 You can PM me. Sorry, just seeing your post from Jan 17, Pool Clown. What does "PM me" mean? Private message. (within this forum) Quote Link to comment Share on other sites More sharing options...
kbdsrg Posted November 8, 2010 Report Share Posted November 8, 2010 We have recently bought a house that has an inground pool. When we first moved in, we had no problems with the spa draining after the pump shut off. Then we found out that we had a leak in our Jandy DE filter so our home warranty company sent someone out here to look at it. I don't know what he did to our equipment, but ever since he came, our spa has been draining every night after our pump shuts off. We've since had the filter replaced with a Pentair and we had our multi port valve replaced as well. I've asked the guy who cleans our pool weekly about it and he said it was because of the leak in our filter. I also asked the company that came and replaced the filter and he said that it was because we had a valve turned on that should be off (the fountain valve). Anyhow, neither of these fixed the problem. I went out today and turned the actuators both to ON1 (the actuator closest to the pump was already set on ON1 and the other one was set at ON2) and then turned the valves all to on. Needless to say, I'm at a loss as to what is wrong with it. I took a picture of the equipment so hopefully I can figure out how to attach it here and anyone who knows what, if anything is turned the wrong way, I would love to hear from you! Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted November 8, 2010 Report Share Posted November 8, 2010 Flip the switch on the return side (higher) valve. Make it so the handle is pointing to the valve labeled pool, and that should solve the draining at night problem. Question: Why is the Jandy temp sensor just hanging off the pipe near the pump inlet? Quote Link to comment Share on other sites More sharing options...
kbdsrg Posted November 8, 2010 Report Share Posted November 8, 2010 Flip the switch on the return side (higher) valve. Make it so the handle is pointing to the valve labeled pool, and that should solve the draining at night problem. Ok, I flipped the switch and the valve didn't go all the way over, it stops about 3/4 of the way. I have attached a picture of that as well. I'm wondering if there is something in there that is causing it to jam? Question: Why is the Jandy temp sensor just hanging off the pipe near the pump inlet? I have no idea. I'm assuming you are talking about the little circle thing with the green thing around the wire? (Can you tell I'm not a pool expert?) Where is is supposed to be? What does it do? And what kind of problems am I looking at without having it where it's supposed to be? Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted November 9, 2010 Report Share Posted November 9, 2010 Never mind about the little circle thing. It looks like it was replaced, and the installer just left the old one hanging there. Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted November 9, 2010 Report Share Posted November 9, 2010 The valve actuator may just be out of alignment, or there is something in the valve jamming it (Like you said). Quote Link to comment Share on other sites More sharing options...
mvk Posted November 15, 2010 Report Share Posted November 15, 2010 Hello- I have the same problem with my spa draining down 6-8 inches after the filtering stops. My question: The valves that switch from pool to spa. Are these the ones that need to be cleaned? I have 2 of them on my pool/spa setup. Or Is it the valve that is straight through with a blue handle (don't know what that does).. Thank you in advance Quote Link to comment Share on other sites More sharing options...
Pool Clown Posted November 15, 2010 Report Share Posted November 15, 2010 The check valve is what i would look at first. Quote Link to comment Share on other sites More sharing options...
mvk Posted November 15, 2010 Report Share Posted November 15, 2010 The check valve is what i would look at first. Quote Link to comment Share on other sites More sharing options...
rtris22 Posted December 1, 2010 Report Share Posted December 1, 2010 Im having the same problems. The spa drains when the pump/filter turns off. I have attached pics if anyone can help. Thank you or pls Email me Quote Link to comment Share on other sites More sharing options...
