Sorry, I was not sure if the spa was supposed to be running or the pool. I had put it into service mode and pressed on the spa button and nothing turned on, so I did what you said while the pool was running. When the spa turns on tonight during the freeze protect I will try it. My check valves are Jandy. I was thinking about purchasing a new one tommorrow, I am thinking maybe the spring is allowing water to seep through. Will all of this cause the suction for my skimmer and shark cleaner to be non- existent? Thanks for your input, I have no idea about pools and I am the more mechanicaly inclined over my husband. Also, with the spa acting up like this, is this why the pressure is so high? Oh and my heater has a light on for the pressure sw?
Okay, just after the last post I went outside and the spa was on. The funny thing is, is that it was doing the waterfall effect while in spa mode. I do not think it is supposed to be pushing water out over into the pool while in spa mode. It is supposed to be just moving the water inside of it with the jets. So I went over and flipped the switch on the actuator for the spa suction and it did not stop the water from spilling over? So I switched it back and flipped the switch for the actuator on the jet side and it stoped the spill over but also the movement in the spa. I have no idea what is going on. Thank you again.
