Spa Guru, thanks so much for the quick reply! I sincerely appreciate it.
You called it on the Jandy valve actuators. I found the $100 actuator here.
I am glad you noticed the 90 degree angle aspect. That is confusing me. Shouldn't the valve only point at where "spa" and "pool" have been written (by my installer)? Right now, in the picture, it is not pointing (on) to either of these.
I am not sure how to adjust the actuator, but I will look into it.
Also, I wanted to be able to use the spa when some friends visited, despite this issue. I read the valve actuator manual and was happy to see a section on a manual override. I set the valve to spa manually, but nothing happened -- literally -- the filter came on, but the spa did not heat and water also did not come out of the pool fill pipe. No water flow that I could see. Any thoughts there? Shouldn't it be possible to get the spa working manually?
Thanks again for your assistance!!
Brent
