waldorbigbill Posted May 27, 2007 Report Share Posted May 27, 2007 Hey any idea how to fix Cloudy hazy water? I have a Marquis Rewards. Water was fine two days ago then water turned. I keep it at 100% water is only two weeks old. I Had water test before it turn cloudy add everything they said including something for the minerals in my water. Thanks Bill Quote Link to comment Share on other sites More sharing options...
bigb4uaz Posted May 28, 2007 Report Share Posted May 28, 2007 Hey any idea how to fix Cloudy hazy water? I have a Marquis Rewards. Water was fine two days ago then water turned. I keep it at 100% water is only two weeks old. I Had water test before it turn cloudy add everything they said including something for the minerals in my water. Thanks Bill When that happens to me...I completely hose the filter with a high pressure washer and then I add about 4 tablespoons of water clarifier........ hope this helps....Usually just hosing down the filter helps..... Quote Link to comment Share on other sites More sharing options...
waldorbigbill Posted May 30, 2007 Author Report Share Posted May 30, 2007 Things only getting worse try clarify twice no good now getting a slime feeling any advice. chec were on lower end now all really high except borime and hardness are both low. Quote Link to comment Share on other sites More sharing options...
Roger Posted May 30, 2007 Report Share Posted May 30, 2007 I stuggled with Bromine also, make sure you have a good bromine reserve and shock, with a clean filter and let circulate for a couple days. Quote Link to comment Share on other sites More sharing options...
ebeing Posted May 31, 2007 Report Share Posted May 31, 2007 Sounds like your ph may be a little off, let us know how it goes Quote Link to comment Share on other sites More sharing options...
