mike 96161 Posted March 22 Report Share Posted March 22 We have a 2020 Hot Springs Prodigy Spa. When I rotate the SmartJet divert valve 360 degrees, only the jets on the far side of the spa shoot water. The jets on the other three sides release a small amount of water. The diverter does not change the flows to the jets no matter what position it is in. I can't find a parts diagram that shows the diverter valve... Any ideas? Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted March 23 Report Share Posted March 23 Turn main power off. Pop the handle off and then unscrew the round part underneath. Under it you will see the diverter valve. Often people try to turn the handle when the pump is running in high speed. There is a lot of pressure there when the pump is in high and it can break the valve stem. Always turn the pump off or to low before diverting water flow. Quote Link to comment Share on other sites More sharing options...
