edgraham Posted December 12, 2023 Report Share Posted December 12, 2023 I came home the other day and noticed my hot tub had no power, or appeared to have no power. I went and checked the breaker and it was fine. I reset it just to see if the hot tub would power up, and "560" flased on the readout and nothing else happened. It completely dead with exception of the 560 and i cant find anything about it. Retailer where I bought it wants $150 just to show up. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted December 13, 2023 Report Share Posted December 13, 2023 Post photos of the circuit board, Topside and schematic on inside cover if there is one so we can see what system you have. 1 Quote Link to comment Share on other sites More sharing options...
edgraham Posted February 9 Author Report Share Posted February 9 On 12/13/2023 at 8:27 AM, CanadianSpaTech said: Post photos of the circuit board, Topside and schematic on inside cover if there is one so we can see what system you have. So My GFCI braker keeps tripping also. I tried replacing the breaker and nothing changed. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted February 9 Report Share Posted February 9 Start by disconnecting the heater (most common cause for a trip) J9 and J10 from the board and see if breaker holds. Post result. Do you have a multi meter and knowledge of how to use it to test for power? Quote Link to comment Share on other sites More sharing options...
edgraham Posted February 11 Author Report Share Posted February 11 Will check that this morning and yes, I have a neter and know how to use it. Quote Link to comment Share on other sites More sharing options...
edgraham Posted February 11 Author Report Share Posted February 11 Disconnected the heater. Disconnected Heater in and out. No change. Still trips breaker. I wish I knew what this 560 was. It flashed up so fast that you blink and you miss it. I have checked all the wires on the board for shorts and cant find a damn thing. Quote Link to comment Share on other sites More sharing options...
edgraham Posted February 11 Author Report Share Posted February 11 Just disconnected the pumps one at a time and no change either. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted February 11 Report Share Posted February 11 https://www.manualslib.com/manual/78934/Jacuzzi-Premium-J-325.html?page=34#manual Start at the beginning and follow the power... Disconnect the main power going to the pack at TB1 and see if it holds. Next disconnect all 6 connections along bottom edge. Does it hold? Then connect the 2 on the left j5 j6 does it hold? Then the next 2 J7 J8 Does it hold? Post photos of the newly installed GFCI so we can see how it is wired. Post results. At some point you may want to pull the board and look on the back for darkened or burnt areas Before you swapped the breaker would the GFCI hold but just nothing happens? 1 Quote Link to comment Share on other sites More sharing options...
edgraham Posted February 11 Author Report Share Posted February 11 Verified the old GFCI worked so I put it back in. Does not trip with J5/J6 off. Trips when they are back on. J 6/7/8/9/10/11/12/16/17/18/19/20/21 do not affect if it trips. I do not have J13/14 When I disconnect J15 it does not trip immeadiately. but after about 5 seconds the breaker trips. When connected it trips immeadiately. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted February 12 Report Share Posted February 12 Disconnect J15, 16 and 17 and try. If it still trips remove the board and look on the back for any damage. When removing the board disconnect everything but J5 and 6 and try. Does it trip? 1 Quote Link to comment Share on other sites More sharing options...
edgraham Posted February 25 Author Report Share Posted February 25 On 2/12/2024 at 8:21 AM, CanadianSpaTech said: Disconnect J15, 16 and 17 and try. If it still trips remove the board and look on the back for any damage. When removing the board disconnect everything but J5 and 6 and try. Does it trip? OK, So no burn marks on the board. it looks clean. When I disconnect 15/16/17 it does not trip. If I connect 16/17 it trips after about 5 seconds. Did not try the j5/6 thing. I forgot...lol But with 15/16/17 disconnected it runs fine with Pump 1 out of the loop. I am gonna give it a once over. Quote Link to comment Share on other sites More sharing options...
