Ross94 Posted October 23, 2023 Report Share Posted October 23, 2023 Hi, We have a Masterspa Getaway 6 Hot Tub. I am having issues suddenly with the circulation pump barely sucking water in, the system is separate to the jets which operate normally. When I remove the filter and feel down near the inlet there is a small amount of suction but nearly enough as usual, it is not enough to pull any dirty off the top of the water Things I have tried; running a hose pipe down the inlet hole using a wet vac on the inlet hole loosening the joint either side of the circulation pump, I couldn’t hear any air escape before the water came out using a plunger on the hole Nothing seems to make it any better, the pump is operating and is making the normal sound but severe lack of suction? could anyone suggest anything else? Thankyou - Ross Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted October 23, 2023 Report Share Posted October 23, 2023 Is there a chance anything (kids toy, sponge, g string) got past the filters and down the hole? At the bottom of the filter housing there should be a spring loaded flapper (Bypass valve) that is closed when the pump is on low speed and pulls water through the filter. When the pump is engaged in high speed the flapper opens and pulls the extra water need to supply the pump from the foot well suctions. The part that opens with the spring attached can break off In both scenarios the "item" will get sucked into the face of the pump and restrict water flow. Remove the union at the face of the pump and collect your prize. Quote Link to comment Share on other sites More sharing options...
Ross94 Posted October 24, 2023 Author Report Share Posted October 24, 2023 Thankyou, I have drained the hot tub I am going to disconnect the pump today at either side and see if I can find any debris in there, touch wood! Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted October 24, 2023 Report Share Posted October 24, 2023 look to see if the flapper is missing at bottom of filter housing Quote Link to comment Share on other sites More sharing options...
