NancyL17 Posted September 24, 2023 Report Share Posted September 24, 2023 Hi, we just had our older Master Spa drained & cleaned. And it immediately started leaking. No problems with it before and we had it drained and cleaned many times. What could have happened during the drain and clean to cause the pump to leak? (They came out the next day and said it was the wet end of the pump leaking.) I'm wondering if it was left running for a couple of hours while empty for a couple of hours during the clean, if this could have triggered the leak. Would appreciate insight. Thank you! Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted September 27, 2023 Report Share Posted September 27, 2023 On 9/24/2023 at 1:18 AM, NancyL17 said: I'm wondering if it was left running for a couple of hours while empty for a couple of hours during the clean, Sure. is it leaking in between the wet end and the motor or from one of the unions connecting the plumbing to the pump? If in between the wet end and the motor you will nee to rebuild it with a new seal and impeller. Quote Link to comment Share on other sites More sharing options...
