Stewart Posted March 26, 2023 Report Share Posted March 26, 2023 Hi , I have an outdoor living hot tub. The tub has been turned off for 9 months due to my wife's recovery from an operation. I cleaned and booted it up today. The tub is inside a summer house. the control panel is a Gecko build Oct 2015 16.21.48. When the hot tub (32amp) is turned on it runs through both jet cycles (air and water i think) which work fine. Then the wheel which usually spins to state that the panel is booting stops spinning . It would normally start to circulate water and heat. I replaced the heating element last year which was tripping the RCBO board and as this is not happening i guess this is ok. If anyone has any ideas where to start i would appreciate it. Thanks Quote Link to comment Share on other sites More sharing options...
cranbiz Posted March 27, 2023 Report Share Posted March 27, 2023 Post up pictures of that actual control pack and the wiring diagram. Look at the board, are there any capacitors exhibiting bulging? Calling @CanadianSpaTech Quote Link to comment Share on other sites More sharing options...
