riverbanks17 Posted November 15, 2022 Report Share Posted November 15, 2022 Does any one know what the low level learning settings are for an older in.xm1 spa pack, everything I can find online has settings for the in.xm or in.xm2. My current in.xm1 only has 8 low level learning settings. Is it possible to just go through each setting to see which one makes everything work? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
In Hot Water Posted November 17, 2022 Report Share Posted November 17, 2022 Unfortunately if you don't know the setting, you may have to sit through all of them. Try to research the spa model, and or the manufacturer. Someone here may know of the setting with more info on what you have. Quote Link to comment Share on other sites More sharing options...
riverbanks17 Posted November 17, 2022 Author Report Share Posted November 17, 2022 Ended up trying most of them, probably not the ideal way but it worked. The setting ended up being number 5, 1 pump 2spds, 1 pump 1spd, blower, ozonator. You can tell on the keypad what components are being learned with each setting so it’s just trial and error. Hope this helps. Quote Link to comment Share on other sites More sharing options...
Couch67 Posted November 19, 2022 Report Share Posted November 19, 2022 You can also contact Gecko (I can't seem to locate it but their contact info is online). I emailed them earlier this year with a question about an older in.xe system I had, they responded by email within the day. Quote Link to comment Share on other sites More sharing options...
