HarryVH Posted April 25, 2022 Report Share Posted April 25, 2022 Hi. Brand new to this form and I did try search for help on my problem first but couldn't find any but got some ideas though. I currently have a Hydropool Serenity tub which is quite a few years old but no leaks. The spa pak went in it which was a Gecko S Class. A friend gave me a Balboa BC612E Mach3 pak and I installed it. I am not sure if this came from a two pump Beachcomber tub so I wangted to configure this into a one pump system but I can not find the wiring diagrams. I am told that it could be as easy as a dip switch to tell it that it only has one pump now so any help in this would be appreciated. Thanks. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted April 25, 2022 Report Share Posted April 25, 2022 Should be a schematic on the inside cover. Try this: https://www.yumpu.com/en/document/read/44928551/balboa-el1000-mach-3-v32-tech-sheet-balboa-direct Quote Link to comment Share on other sites More sharing options...
HarryVH Posted April 25, 2022 Author Report Share Posted April 25, 2022 Thanks. I will have another go at this Wednesday. Right now it works but the pump will shut off and leave the heater on causing the over heat error so this is why I thought it may have had two pumps hooked up to it. Quote Link to comment Share on other sites More sharing options...
HarryVH Posted April 25, 2022 Author Report Share Posted April 25, 2022 I should also have asked if it makes a difference that mine is slightly different than this manual shows? Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted April 26, 2022 Report Share Posted April 26, 2022 11 hours ago, HarryVH said: I should also have asked if it makes a difference that mine is slightly different than this manual shows? Need to post photos of the circuit board and the schematic on the inside cover so we can see what you have and how it is set up. Quote Link to comment Share on other sites More sharing options...
Frustraded2022 Posted April 26, 2022 Report Share Posted April 26, 2022 Canadian Spa Tech do you for Canadian Spa Company out of Oakville Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted April 26, 2022 Report Share Posted April 26, 2022 45 minutes ago, Frustraded2022 said: Canadian Spa Tech do you for Canadian Spa Company out of Oakville No.. Out of Milton ON and service Halton Region and surrounding communities. Please start your own thread/post if you are having issues Quote Link to comment Share on other sites More sharing options...
HarryVH Posted April 27, 2022 Author Report Share Posted April 27, 2022 Thanks CanadianSpaTech for your advice. I did some more research and based on your link I was able to reset the system, change the switches and it is now running properly with one pump. Appreciate your help. 1 Quote Link to comment Share on other sites More sharing options...
