Spa choice hobart Posted August 7, 2021 Report Share Posted August 7, 2021 Hoping someone can shed some light on external heat pump control on the yj-3 gecko controller. In-grid won't work so want to add a relay from heater control to control heat pump remote start. Has any one done this or just run the heat pump using just the flow switch on the heatpump and set temp 1 degree over spa set temp. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted August 7, 2021 Report Share Posted August 7, 2021 Why won't In.Grid work? https://www.geckodocs.com/ https://www.geckotv.ca/ingrid https://www.geckotv.ca/protipsindex#Yseries 1 Quote Link to comment Share on other sites More sharing options...
Bigbaddewulf Posted March 8 Report Share Posted March 8 Hello, did you or anyone else figure this out? I’ve added a heat pump and powered it from the controller. The the controller stops heating my heat pump keeps blinking on and off due to no powers. Considering powering the heat pump from a wall socket but then I’ll get a flow error. Gecko control plus relay option would work best if possible or considering adding a small central heating pump powered by the heat pump and controller it via the heat pump schedule. Any help would be greatly appreciated Quote Link to comment Share on other sites More sharing options...
