marcopolo94 Posted July 3, 2021 Report Share Posted July 3, 2021 I have my spa that no longer heats up and no longer makes ozone bubbles and the green and blue lights flashing. I removed the filters to see if it starts again but nothing. I bypassed the pressure switch but the pump does not restart cf photo I think the pump is dead. Are you of the same opinion? Or could it be something else? Thank you for your answers IMG_3981.HEIC Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted July 3, 2021 Report Share Posted July 3, 2021 If the circ pump is not putting tiny bubbles from the footwell it is probably bad. I would test the thermistors first, just to be sure. Do you have a multimeter? Google "hot springs thermistor testing" for videos. Post results. 1 Quote Link to comment Share on other sites More sharing options...
marcopolo94 Posted July 3, 2021 Author Report Share Posted July 3, 2021 it is the pump which was dead I have just changed it but now I only have the green light flashing. as you say i must also have a problem with the temperature probes Quote Link to comment Share on other sites More sharing options...
marcopolo94 Posted July 3, 2021 Author Report Share Posted July 3, 2021 I just tested they all give 11.23kohm Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted July 4, 2021 Report Share Posted July 4, 2021 On the circuit board are 3 LEDs labelled lim ok, htr on, and control unplugged. Which of these are lit? If you put the filters back in remove them again and leave them out. Do you have lots of champaign bubbles from the footwell jet? Quote Link to comment Share on other sites More sharing options...
marcopolo94 Posted July 4, 2021 Author Report Share Posted July 4, 2021 I don't know what happened but now the blue light is on and the spa is heating up. I do not understand Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted July 4, 2021 Report Share Posted July 4, 2021 You were going to fix it and it knew it. Quote Link to comment Share on other sites More sharing options...
marcopolo94 Posted July 4, 2021 Author Report Share Posted July 4, 2021 ahah Quote Link to comment Share on other sites More sharing options...
marcopolo94 Posted July 16, 2021 Author Report Share Posted July 16, 2021 Hello, I have the spa which is flashing again and not heating up. I tested and I have no current reaching "no fault" what would happen if I feed it directly into 220v ty for answer Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted July 16, 2021 Report Share Posted July 16, 2021 Your spa will overheat, melt thin fittings, dump scalding water all over the place, then catch fire. Sounds like an exiting day tomorrow! 😉 Are the breakers on? Remove the filter. 1 Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted July 16, 2021 Report Share Posted July 16, 2021 On 7/3/2021 at 10:02 PM, RDspaguy said: On the circuit board are 3 LEDs labelled lim ok, htr on, and control unplugged. Which of these are lit? If you put the filters back in remove them again and leave them out. Do you have lots of champaign bubbles from the footwell jet? Quote Link to comment Share on other sites More sharing options...
marcopolo94 Posted July 17, 2021 Author Report Share Posted July 17, 2021 J'ai acheté un nouveau filtre car le mien était assez vieux. alors oui j'ai des bulles de champagne. ok je chercherais les leds Il y a 6 heures, RDspaguy a dit : Votre spa va surchauffer, faire fondre des raccords hachés, déverser de l'eau bouillante partout, puis prendre feu. Ça a l'air d'être une journée excitante demain ! 😉 Les disjoncteurs sont-ils activés ? retirer le filtre. MDR I don't have a circuit breaker Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted July 17, 2021 Report Share Posted July 17, 2021 Then how do you turn off power to the spa? I'm sorry, but I don't speak French, or whatever that is. 1 Quote Link to comment Share on other sites More sharing options...
marcopolo94 Posted July 17, 2021 Author Report Share Posted July 17, 2021 Sorry I bought a new filter because mine was quite old. so yes I have champagne bubbles. ok i would look for the leds I turn off at the electrical panel Quote Link to comment Share on other sites More sharing options...
