Lester C Posted May 17, 2021 Report Share Posted May 17, 2021 I have a Leisure Bay spa with a Polysteel P1 control panel mounted on top. The spa came with the house I bought. Previous owner said heating element was bad so I replaced it and it works fine. They have it hard wired to it’s own breaker in the panel box. When I flip the breaker, the spa comes on and runs fine. The heater works as it should, however, I cannot control the power to the pump and the jets with the panel. I can enter the unit into the different modes, turn the light on inside, change the temp, etc. It seems as if I press the jet button on the panel, it turns the heater off and the jets keep going. Also, how can I determine if I have a 2 speed motor or not? I’m not sure if my panel is bad or if I’m doing something wrong. The owners manual online is a little vague. Any suggestions? Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted May 17, 2021 Report Share Posted May 17, 2021 Post a pic of your equipment area, circuit board, and wiring diagram. Also of the specs sticker on the motor that shows motor electrical info. Do you have a voltmeter? Quote Link to comment Share on other sites More sharing options...
Lester C Posted May 17, 2021 Author Report Share Posted May 17, 2021 I do have a voltmeter. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted May 18, 2021 Report Share Posted May 18, 2021 It's plugged in the wrong plug. Move it to the one closest to the power wires. 2 Quote Link to comment Share on other sites More sharing options...
Lester C Posted May 18, 2021 Author Report Share Posted May 18, 2021 So move it from J50 to J23? Maybe this is why the previous owner had it hard wired haha. I’ll check that out tomorrow and let you know. Thank you for your help. Quote Link to comment Share on other sites More sharing options...
Lester C Posted May 18, 2021 Author Report Share Posted May 18, 2021 20 hours ago, RDspaguy said: It's plugged in the wrong plug. Move it to the one closest to the power wires. You are correct sir, after moving it over to J23 it works perfectly. Thank you so much for your help. Any recommendations on where to get a replacement cover? 1 Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted May 19, 2021 Report Share Posted May 19, 2021 Affordable spa covers are the cheapest I have found. 2 Quote Link to comment Share on other sites More sharing options...
Lester C Posted May 19, 2021 Author Report Share Posted May 19, 2021 3 hours ago, RDspaguy said: Affordable spa covers are the cheapest I have found. Thank you for all your help 1 Quote Link to comment Share on other sites More sharing options...
