Hottub won't stop running
Drewtub
Set at F2. If it is set at say F8 that means it will run for 8 hours out of 12 or 16 hours out of every 24
Preset Filter Cycles. The first filter cycle begins 6 minutes after the spa is energized. The second filter cycle begins 12 hours later. Filter duration is programmable for 2, 4, 6, 8 or (12 hours continuous filtration, indicated by “FC”). The default filter time is 2 hours. To program, press “Temp,” then “Jets.” Press “Temp” to adjust. Press “Jets” to exit programming.
There is a jumper pin on the circuit board that can be set to run it either 2 hour filter cycles or 5 hour filter cycles so if it is set a the 5 hour setting it will run a total fo 10 hours a day 5 hours in the AM and 5 hours in the PM
Need a photo of the schematic on the inside cover of the pack.
