contact634 Posted October 28, 2020 Report Share Posted October 28, 2020 so today I installed a ultra pure ozone generator on my 2001 sundance altamar pretty straight forward its plug and play with the molex conector previous owner removed the ozone injector so i had to reinstall one but I have a few questions installed it powered tub one turned temp up recirc pump kicked on ozone powered up and indicated so on lcd turned tub off closed up cabinet turned it on turned heat up and no ozone unit was not on as no light from it and no lcd indicator does it only come on for programed filter cycles? I also notice bubbles come out of the heater jet when ozone is on or off they never did before Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted October 29, 2020 Report Share Posted October 29, 2020 The bubbles are there whether it's on or off, the injector draws air through the ozonator either way. The system will turn off the ozonator for a set period, 30 minutes I think, whenever you touch a button on the topside. In the early years of ozone use it was directly injected at the jet and would gas off at the surface as ozone, which they didn't want you breathing. Modern spas don't have that issue any more, but the trend is already established so most control manufacturers include that in their systems. It's kinda like having economy mode on a spa with a 24/7 circulation pump... Pointless, but everyone does it anyway. 1 Quote Link to comment Share on other sites More sharing options...
