GBH
Silver Ion Cartridge Y/N & Ozonator Y/N
So, I got my new Envoy this week.  All hooked up.  Questions now are:
What is the benefit of adding a Silver Ion Cartridge?  It is a salt system tub.
Can you run an ozonator and the salt system at the same time?  Would that even be needed?
Share this post
Link to post
To quote @RDspaguy from another thread
Quote
big fan of ozone for it's ability to oxidize. I also like mineral purifiers (silver ion) but if I had to choose it would be ozone all day long.
Ozone burns off organic contaminants through oxidation (like shock) but is such a strong oxidizer that it even reacts with free chlorine. This means you can shock after heavy use and not have to soak in a bleach bath the next day, because the ozone will burn off all the chloramines and most of the chlorine overnight.
Silver ion inhibits reproduction of single-celled organisms and (slowly) destroys them. It does not eliminate the need for chlorine, but allows you to use less. It is a little pricey compared to most chemicals, but worth it in my not-so-humble opinion. I use nature2 or spa frog. I have not tried any of the liquid varieties but assume they are similar.
I have a 2019 Hotspring Jetsetter (awesome tub, can't wait to upgrade to the Envoy as well).   I rock an ozonator and Silver mineral cartridge in my setup.    Although personally I am using a teaspoon of Dichlor56 after each soak to sanitize instead of using a saltwater cell.      As long as I keep my filters clean and pH balanced (baking soda to boost pH as needed), my water is clean/clear and essentially chlorine free 23 hours later when I hop in for my next soak.  Sure I need to change the water twice as often as a saltwater setup in this tub, but at $2 a refill, I think I can swing $4 a year in water charges haha.
Share this post
Link to post
I consider ozone and salt (chlorine generator) to be counterproductive. Ozone eliminates chlorine, and salt cells create it. Salt cells produce such a high concentration of chlorine that it effectively shocks the chloramines without the frequent need to manually add shock, and so does a part of what ozone does.
I am not a fan of salt chlorine generators even in pools, but ESPECIALLY not in spas.
Share this post
Link to post
