Kube1989 Posted June 5, 2020 Report Share Posted June 5, 2020 Tub is used- says manufacture date is 6-4 (is that June of 2004 or April of 2006?) Night before last circ pump got really noisy for about 30 sec and then popped breaker. Breaker would not reset unless I unplugged circ from spa pack. I put in a new circ pump yesterday and all was well. Tub is at 102 and holds water. Overnight I got the Low Flow. Filters are new, mesh screen is clean and new black plastic inserts in filter wells. This was first night of actual use- was sitting empty for 9 mos. Can the filters need rinsing ALREADY?!? I just don't want to burn the circ pump up. Please advise. Thanks! Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted June 5, 2020 Report Share Posted June 5, 2020 Remove filters for testing. Check flow switch, verify it is open when pump is off and closed when pump is on. Quote Link to comment Share on other sites More sharing options...
