Mikel199 Posted April 3, 2020 Report Share Posted April 3, 2020 Nothing is turning on. Not even the jets Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted April 3, 2020 Report Share Posted April 3, 2020 Try removing filters and reset breaker. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted April 3, 2020 Report Share Posted April 3, 2020 Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted April 3, 2020 Report Share Posted April 3, 2020 What, you didn't want to do it again, Canadaguy? I admit, I sighed audibly before typing my response. Quote Link to comment Share on other sites More sharing options...
Mikel199 Posted April 3, 2020 Author Report Share Posted April 3, 2020 Yes I did. Still nothing Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted April 3, 2020 Report Share Posted April 3, 2020 Did you review the thread from Canadaguy? We just went through this issue with someone else. You might find something useful in there. Check it out and post any questions you might have. Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted April 3, 2020 Report Share Posted April 3, 2020 FYI....Other guy put new sensors and worked for 10 mins and came back again Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted April 3, 2020 Report Share Posted April 3, 2020 Yeah, I heard. I wish he would have tested them as suggested before ordering new. At least he can return them. To the OP: How is it coming? Did anything from the other thread help you out? Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted April 3, 2020 Report Share Posted April 3, 2020 What I find odd is there is an obvious error code and yet I can't find anything relating to the code from Balboa or otherwise Quote Link to comment Share on other sites More sharing options...
CanadianSpaTech Posted April 3, 2020 Report Share Posted April 3, 2020 OP can you post a pic of the inside cover of the spa pack and also any white tags on the circuit board and prom chip. Quote Link to comment Share on other sites More sharing options...
RDspaguy Posted April 4, 2020 Report Share Posted April 4, 2020 Dashes should only show when it is uncertain of the temperature. It isn't really an error, it's like it's loading. This can happen sometimes if it is in sleep mode and between filter cycles, as it needs the pump on to test every few hours IIRC, but it should go away shortly after you turn on the pump and should not keep you from turning on the pump. It acts like a Sundance watchdog, and I keep having to remind myself it is a balboa. Quote Link to comment Share on other sites More sharing options...
