Cusser Posted January 5, 2020 Report Share Posted January 5, 2020 I understand that too-low pH can corrode heating elements in a spa. I have a 31-year-old 240 VAC CalSpa, and it takes screw-in heating elements, look the same as on a home water heater. The first two times I replaced the heating element, I bought from CalSpa by mail, and they were somewhat expensive, and back then I removed the stainless steel manifold which housed the element, a big hassle. Then my daughter figured out that if I cut a recess into the inner plastic shield/liner, then I could unscrew the bad element and guide that into that recess, then simply remove it and install a new element, genius !!! Since then, I've simply purchased 5500W (and occasionally 4500W) elements at the hardware store and used those, either straight or curved-back types, of these configurations. Over the past 25 years I've had the elements go out and sometimes the element threads corrode and will leak, indicating that I need to replace it. Yesterday, when I went to vacuum the spa (see a new different thread), I noticed that all the water had leaked out, the element had corroded and backed out. The stainless steel housing itself is not corroded or damaged, so easy R&R of the element. So I have a question about heating element corrosion, of the threads themselves: Are spa heating elements metallurgically different than home water heater elements, so worth buying specific spa elements themselves? Quote Link to comment Share on other sites More sharing options...
Cusser Posted January 8, 2020 Author Report Share Posted January 8, 2020 My records show the previous element lasted like 13 months. Water pH is just under 8.0. Quote Link to comment Share on other sites More sharing options...
