2010 Hotsprings Envoy Jet 2 replacement
Saxy
   I have a 2010 Envoy and it busted the impeller and began pouring water out of the back of the wet end.   I replaced the impeller with an a used impeller I had saved from another wet end I replaced last year.  When I started the pump I suspect the same thing happened again as water is pouring out of the back again even when the pump is off.     Instead of replacing the wet end I was thinking of replacing the entire unit due to the age of the unit.
   The current pump is a 2HP pump and I believe that it is a 56 Frame.  The label says that it will run at 115V or 230V but I think this is setup as a 230V motor.  unfortunately I did not check the voltage before having to drain the tub.
  I found a reasonable price replacement pump but it is a 48 frame instead of a 56 frame.   What differences will I see with this and will it make mounting it more difficult with the current plumbing not lining up?    The replacement I found that is a 56 frame unit is a 3HP unit.  I did not want to upsize the motor as I was happy with the performance of the 2hp motor.
   Does anyone have any recommendations for a reasonable and easy replacement?
       Thanks!
