Saxy Posted March 5, 2019 Report Share Posted March 5, 2019 I have a 2010 Envoy and it busted the impeller and began pouring water out of the back of the wet end. I replaced the impeller with an a used impeller I had saved from another wet end I replaced last year. When I started the pump I suspect the same thing happened again as water is pouring out of the back again even when the pump is off. Instead of replacing the wet end I was thinking of replacing the entire unit due to the age of the unit. The current pump is a 2HP pump and I believe that it is a 56 Frame. The label says that it will run at 115V or 230V but I think this is setup as a 230V motor. unfortunately I did not check the voltage before having to drain the tub. I found a reasonable price replacement pump but it is a 48 frame instead of a 56 frame. What differences will I see with this and will it make mounting it more difficult with the current plumbing not lining up? The replacement I found that is a 56 frame unit is a 3HP unit. I did not want to upsize the motor as I was happy with the performance of the 2hp motor. Does anyone have any recommendations for a reasonable and easy replacement? Thanks! Quote Link to comment Share on other sites More sharing options...
Hot Spring Official Posted March 6, 2019 Report Share Posted March 6, 2019 Your spa was designed to use a 230volt 2hp pump. You should stay with the original equipment available from local dealer. Quote Link to comment Share on other sites More sharing options...
