jnz Posted June 3, 2014 Report Share Posted June 3, 2014 I have a Image Spas Paradise and need to change the light bulb, but can't figure out how the cover comes off. I've turned counter clockwise on the center and it moves a hair each direction. No further. Here is a picture of the backing. Quote Link to comment Share on other sites More sharing options...
PreservedSwine Posted June 3, 2014 Report Share Posted June 3, 2014 The lens isn't supposed to move at all. I hope you're just talking about the little white plastic housing that holds in the bulb Anyway, if you push in on the little tab with a screwdriver, it will pull right out- no twisting. There are two tabs- 180 degrees opposite each-other - just pick one and push in the tab, and pull (or pry) Quote Link to comment Share on other sites More sharing options...
jnz Posted June 3, 2014 Author Report Share Posted June 3, 2014 Sounds good. Yes, the lens is sealed and the center is what I am trying to remove. Thanks for the help. Quote Link to comment Share on other sites More sharing options...
