I just got this 1999 down east or master spas tub last fall. Two weeks after purchasing the impeller broke apart and was replaced, after that another month later the motor bearings started making noise. The original pump was 2hp and I decided to upgrade to a 3hp motor as the tub never felt the same I replaced the impeller. The new motor came with a wet end and does not seem to put out any more power. The tub appears to have had a lot of pipe work done and I am wondering is there any way to tell if the tub should have come with two motors and have high and low speeds. The tub has always had a two speed motor, but only used one speed. The model number on the outside of the skirt is worn away, but I do have the model of the control box du-h276-dcah. Any help would be much appreciated.
