How Long Should It Run
All pools are different. Start with 4 hrs. This will probably be plenty. You may want to experiment with cutting down the time. Thing is, you will need to also run the cleaner to clean up after storms, etc. That will require a minimum amount of time. Typically if you run the cleaner about 2 hours a day, it will keep the pool clean.
Just be sure that you run the cleaner WITHIN the time you run the filter!
