gmarksteiner Posted July 28, 2013 Report Share Posted July 28, 2013 I have spent hours trying to find a leak in my 2001 grandee. I noticed that the wood base was wet on the side opposite the motor compartment so dug out foam. It was very wet near the base of the tub. I thought I would find the leak in this area, but after digging out a bunch of wet foam near the base, all the other foam above it is dry. I then dug out foam on the side adjacent to the filter compartment and found a similar situation - lots of wet foam near the floor of the tub, but foam above is dry. I've dug towards the seat but am hitting very hard foam that is tough to remove. It seems like maybe there is not much room between the floor and the bottom of the seat. I still feel wet foam there but can't really get it out. I'm thinking maybe there is a leak in the "Y" area that has the pipes from the 2 top jets (of the 3 jet configuration in the center of the side adjacent to the filter), but can't get to these pipes. Has anyone encountered a situation like this? What is the next step? Do I need to access from under the tub? I wish I at least knew I was on the right track, trying to get to this "Y" Does anyone know how far off the bottom of the tub the piping runs? Thanks in advance for any help you can provide. Quote Link to comment Share on other sites More sharing options...
cstultz Posted July 31, 2013 Report Share Posted July 31, 2013 I had a similar issue with mine. It was the connection at the lowest intake. I had to turn it on its side and cut it out to replace. PAIN IN THE BUTT!!! Especially, working on it by yourself. Im having a leak now at the air control. I'm sure its a jet. Just not sure which one. Quote Link to comment Share on other sites More sharing options...
gmarksteiner Posted August 2, 2013 Author Report Share Posted August 2, 2013 cstultz - thank you so much for your reply. I was hoping you could give me some more details on your experience. How difficult is it to cut out the foam on the bottom of the tub and what did you use? How far up into the tub cavity is the plumbing? Also, how often have you had leaks with yours...should I expect to continually be dealing with leaks once the tub is this old? Also, some additional info on my leak...wondering if anyone else has encountered this... I think I might have multiple leaks. Each day I lose about a 1/2" of water no matter whether the tub is completely turned off, whether I run the circulation pump, or whether I run the jets. But I have also had a couple times where I'd check the tub in the morning and I've lost about 4 inches from the night before! But this doesn't always happen so I figured it only happened under certain circumstances, like if I ran the jets (and maybe only with the lever in the 3 o'clock position, or 9 o'clock), or ran the clean cycle. But I've independently tried all those things and it hasn't lost the large amount of water (4 inches) again...only the consistent 1/2" it always loses. Has anyone else encountered this? Quote Link to comment Share on other sites More sharing options...
tiento Posted October 21, 2013 Report Share Posted October 21, 2013 We have a 2001 Hot Springs Prodigy that starting losing 1/2" every day a few months ago. We had an expensive (over $2,000.00) repair for leaks two years ago by the Hot Springs dealer. The current leak is in a new area and we dug out the foam to attack it ourselves. The PVC pipes are cracked as far as we can dig in and I don't see that any repair attempt will be worth it. We live in a moderate climate so I have come to the conclusion that the PVC pipes used by Hot Springs are just not made for longevity. Quote Link to comment Share on other sites More sharing options...
Hot Spring Ace Posted October 21, 2013 Report Share Posted October 21, 2013 We have a 2001 Hot Springs Prodigy that starting losing 1/2" every day a few months ago. We had an expensive (over $2,000.00) repair for leaks two years ago by the Hot Springs dealer. The current leak is in a new area and we dug out the foam to attack it ourselves. The PVC pipes are cracked as far as we can dig in and I don't see that any repair attempt will be worth it. We live in a moderate climate so I have come to the conclusion that the PVC pipes used by Hot Springs are just not made for longevity. Do you mean flex hose or hard pipe? Quote Link to comment Share on other sites More sharing options...
Loopcity Posted October 21, 2013 Report Share Posted October 21, 2013 $2k to fix a leak! Ouch. I'm sorry that you had to go through that. How long did it take to fix it? Quote Link to comment Share on other sites More sharing options...
Loosemoose Posted October 21, 2013 Report Share Posted October 21, 2013 I just bought a new Grandee and reading this makes me feel real good. I sure hope this is not what we have to look forward to. Quote Link to comment Share on other sites More sharing options...
Hot Spring Official Posted October 31, 2013 Report Share Posted October 31, 2013 Hi everyone, Thanks for the posts on this thread; we are listening and want to help! Our spas are made to endure various climates for many, many years. I'd encourage you to call us at 800-999-4688 to address specific concerns as needed and we will be there to support you, in warranty or not, with advice and service arrangements. Thanks, Steve ---Hot Spring Spas--- Quote Link to comment Share on other sites More sharing options...
Dan.The.Spa.Man Posted November 1, 2013 Report Share Posted November 1, 2013 I just bought a new Grandee and reading this makes me feel real good. I sure hope this is not what we have to look forward to. They have sold over a million tubs and the one in question is 13 years old. I think you will be ok. A new Grandee is a great tub. Anyone have a 13 year old car that has ever needed a repair? Tires, brakes, a/c recharge, nothing? No maintenance? Sign me up....I'll buy it. Quote Link to comment Share on other sites More sharing options...
Loosemoose Posted November 1, 2013 Report Share Posted November 1, 2013 Good point Dan, thanks. Quote Link to comment Share on other sites More sharing options...
Marky Mark Posted May 31, 2021 Report Share Posted May 31, 2021 We have owned 2 grandees. Both leaked. You would think for the price they charge that a tub would not leak after only 6 years. Both under warranty but that’s not the point. No more Hotsprings spas once this one shits itself. Terrible. Quote Link to comment Share on other sites More sharing options...
